Apple выпустила смартфон 4 ноября 2017 года в двух различных конфигурациях: A1865, A1901 и дала название iPhone X. Доступны варианты с разными стандартами мобильной связи: GSM или CDMA; с двумя объемами хранилища: 64 или 256 Гб; двумя различными оттенками корпуса: серебристый и Space Gray.
1199вопросов Показать все
Face ID issues after battery replacement (move a little higher/lower)
So after replacing my battery Face ID is no longer able to register my face always saying to move the phone a little higher and then to move the phone a little lower in a loop. I believe the issue is the dot projector. Heres what i’ve tested so far:
  1. putting the original battery back in
  2. cleaning all connectors
  3. reseating back cameras
  4. taking out the sensor module containing the front camera and putting it back in
  5. reseating and cleaning everything on the sensors connected to the screen
  6. called apple support who ran diagnostics and said that they didn’t see any issues with the hardware
  7. cleaned the dot projector with isopropyl alcohol
The front camera and back cameras still work as well as the proximity sensor and ambient light sensor. I also used an old camera to see that the flood illuminator was lighting up. The only thing that refuses to light up is the dot projector. Thanks for the help!
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Rewa has just recently made a video on this. It cannot be fixed by a 3rd repair. You have to go to Apple but even then they won’t work on the phone because you swapped the battery.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Pls share the video link
из
Here comes the latest dot projector repair technique for Face ID move iPhone a little lower/higher
iPhone XS Max Face ID Not Working Fixed - Dot Projector Repair
Оценка 0
Добавьте свой ответ
Taylor Vandenberg будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 10
За последние 30 дней: 52
За всё время: 7,325
