Smartphone designed by Xiaomi in the Redmi Note line.
56вопросов Показать все
battery is emty .cherging is not happeninng and battery gone dryied
sir my redmi note 4 is not openinng .i replaced with new battery but worked till the battery is emty .cherging is not happeninng and battery gone dryied and mobile is not opening. its totally gone dead . when put charging only red light is blinking and not openging. i showed mobile local service man he tolled display is gone and toled to replace the display. pls guied me to solve the problem. im helpless
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
vasanth kombettu  this “replaced with new battery but worked till the battery is emty” shows that your phone is not charging. It has nothing to do with the dispaly. Your phone will need a new USB charging port at least. It is possible that this is also caused by a bad charging circuit but for now, start with a new charging port. something like this will be the start to fixing your mobile phone.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
vasanth kombettu будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 57
