Lenovo Essential G560. This laptop has a 15.6" screen, along with a full keyboard with number pad.
On upgrading the RAM windows just dies
My Laptop supports max frequency of 8500 Mhz but I later I realized that I have installed a 10600S (2GB DDR3) in it and its working but its not sufficient for Windows 10. Its an old laptop and I think of using it as a server.
So I took a 4 GB DDR3 with 12800S (1600 Mhz) from my other laptop and installed in it, it POSTed fine but Windows is crashing. So I want to buy a RAM (1333 Mhz) but I don't know if it will work or not. The Samsung 1333 Mhz RAM stick is cheaper and 1066 Mhz Stick is costly, I know they run at lower frequency but will they run?
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
When upgrading memory, it’s always safest to use brand/speed/type of RAM recommended on the motherboard’s manufacturer’s website. In a pinch, you can try the instructions provided in the following link (included in the instructions is a link to buy the correct RAM from Amazon):
Lenovo Essential G560 RAM Replacement and install 4gb RAM
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Sourabh Thakur будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 7
За всё время: 93
