When I connect the charger it keeps turning on and off fast
The charger lamp turns on and off fast as if the wire is shaking and it doesn't charge
Это хороший вопрос?
Это хороший вопрос?
Are you able to boot into Windows normally?
If the battery is not charging, it's either a...
Bad battery
Bad charging circuit (faulty motherboard)
Bad AC adapter (You can check with an alternate adapter)
You should reach out to the manufacturer for support/warranty service, or consider returning the laptop for replacement.
Был ли этот ответ полезен?
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 5
За всё время: 104
