Основная страница для телефонов Android.
33690вопросов Показать все
Hi, my android charger seems to be suctioning the charging battery...
My android charger, which has a SAMSUNG cable…I use it on any device I use. But the problem is, it doesn’t charge the devices. Instead, it slurps or suctions the battery from the electronic instead. That is why it is from 12% when I charged it, but after a while, I checked how it’s going, yet now the battery is 1% charging. Any help, please?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi Ashley!
Is it your charger which isn’t working? Or is it the charge port on your phone which is defective? Could also be your battery which is not charging anymore.
Did you run tests with another charger?
Был ли этот ответ полезен?
Оценка 1
3 Комментариев:
The Charger Port is fine but I think it's the cable's problem. Also, my battery is also fine. It can be charged. Should I just buy another then?
из
Another new charger?
из
Hi!
Yes, try with another charger. I personally think this will resolve it.
PS: Merry Xmas everyone!
из
My opinion is that the charger is broken. Use a new Samsung charger for that particular phone. Don’t cheap out on this as it can break your phone. Stop using your Samsung charger with other devices and only use it with it’s original one. I recommend using the original chargers for each other device but if this isn’t possible, at least keep the phone charger only for the phone and a separate one for the rest.
Оценка 0
Добавьте свой ответ
Ashley будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 39
