How do I fix my wine-y keyboard?
Over a week ago I spilled a glass of wine on my keyboard. I mopped it up immediately and used a hairdryer (on no heat) to dry it out the best I could.
Certain keys won't work at all (a,s,e . . . all very necessary) and sometimes a there was a repetitive dinging and as a letter would zip repeatedly across the page.
When I returned home, the computer seems to work just fine as long as I'm using my new bluetooth keyboard and magic mouse.
Is there anything I should do to open it up and clean out any residual stickiness or does it need to go away to a mac hospital for a tuneup?
Thnx!
Это хороший вопрос?
Оценка 7
Добавить комментарий
Ответов (2)
Выбранное решение
It's interesting to completely open a keyboard and look how it works inside. There a many plastic sheet with conductive lines called traces. Looks like a diagram and each key has a specific trace. When you push on a keyboard key the action is transfered to a small rubber button under the key that initiate an electrical contact on the sheet traces and the chosen character is recorded by the processor and transfered to the screen so you can see it. When liquid is dropped on the keyboard it may reach the internal sheets and dissolve part of the electrical traces causing a key malfunction, the electrical current flow being interrupted. Wine can easily dissolve the traces and that can't be repaired. You have to replace the keyboard.
Был ли этот ответ полезен?
Оценка 8
Try popping up the keys and wiping them down with a wet paper towel, though unfortunately you may need to replace your keyboard.
Оценка 3
3 Комментариев:
Thanks.
One of the answers suggested that I pop up some keys and while I thought about that, I didn't know HOW to without breaking them off. I even thought about removing those four tiny screws on either side so that I could lift off the whole thing.
But then, I remembered some of my dad's attempted tv repairs from the 50's that ALWAYS resulted in a more expensive professional repair.
A new keyboard is in my near future.
Thanks again!
из
It helps to take off the key and clean under when the key is sticky (but responding) but when the key doesn't respond at all then the internal layers have been affected by the liquid and there's no possible recovery. A keyboard swap is the only solution.
из
Popping them off with a pen is good.
из
Добавьте свой ответ
sandy Sober будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 10
За всё время: 17,378
