Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
220вопросов Показать все
Why does my ipad not work after digitizer,LCD and battery replacement?
I recently replaced a iPad mini 2 digitizer and I accidently broke the LCD, so I ordered one and replaced it. It works, but when I turned it on it blinked the apple logo for a second and then it would just be a black, dim light and didn’t do anything else. When plugging it in to iTunes, it did not show up, but while windows was setting up the device, it said The iPad was in some sort of recovery mode. I don’t know what o do. I have replaced the battery and nothing, Help?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Check for pry damage around the connectors. Also download 3utool, connect the ipad and see if it detects it as you can use this to kick it out of recovery mode.
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Just found your answer after like, almost 3 years haha. But hey, it turned out to be pry damage lmao. This was back when I began to fix things :D
из
@thesanti_exe lol there are plenty of videos older than 3 years on youtube that show pry damage repairs
из
Добавьте свой ответ
Santiッ будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 65
