Apple AirPods are wireless headphones released December 2016.
94вопросов Показать все
1st gen AirPods disconnecting after firmware upgrade
My AirPods disconnect after a short while when in use with iOS devices. There are no problems when using non-Apple products or in use with a MacBook.
The AirPods were working absolutely fine for more than two years. The problem started in July 2019 which happened to coincide with the automatic upgrade of the firmware to ver. 6.7.8.
My wife’s AirPods which were bought at the same time as mine are displaying the exact same problems. We are both on firmware 6.8.8 now but the problem continues. I have consulted Apple and they have offered to replace the AirPods against a repair fee but I have declined this as I am certain the problem is related to the firmware.
Unfortunately there is no way to roll back the firmware. I suppose my only option is to wait for Apple to update the current defect firmware to one that resolves the problem. However I could suspect that this is done intentionally to get me to upgrade to newer AirPods.
Does anyone have any advice?
Это хороший вопрос?
Оценка 4
15 Комментариев
Me me too, I think this is a crafty way for apple to make people replace the airpod with a new one, &&^& you apple
из
been having the same issue for months now, any fix yet?
из
I buy another earbuds (not apple).
из
i’m also seeing this issue for a while now since early 2020. any hopes getting the issue resolved by Apple?
из
same case here ! I’m thinking of switching to android because apple has full control over our devices. they upgrade them whenever they want and there’s no way to downgrade!
из
Показать 10 больше комментариев
Добавить комментарий
1 ответ
Выбранное решение
You’re right there. This is a software issue. There are other reports of this happening with version 6.7.8. Apple recommends a reset. However, this often does not work. https://discussions.apple.com/thread/250... I probably would get new earbuds, but probably NOT Airpods. There is no software upgrades available, and who knows if Apple will do this in the future to their later models.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
st2en будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 66
За всё время: 15,416
