Внешний жесткий диск с интерфейсами USB 2.0 и FireWire 400/800. Выпускается в вариантах емкостью от 320 ГБ до 2 ТБ.
Data Recovery Issues after restore
Hello everyone.
I have a western digital which I had stored videos from my macbook pro using the software final cut pro.
About a week back the hard drive crashed and I took the external hard drive and attached it to a PC running windows 7 and ran a recovery program called EASEUS recovery. I was successful recovering the the videos , but I can't play the videos neither on a mac or pc. Keep getting an error that the file is invalid. Is there a special software or a particular way to run recovery which would enable me to recover the videos properly.
All help is appreciated
Это хороший вопрос?
Счет 0
1 Комментарий
Hi can i suggest that you check one if the files info and comfirm if the size of the file tally with what you have?
из Поделиться
Добавить комментарий
3 Ответов
Выбранное решение
I would contact the maker of the software you used for assistance. They probably used a file system locked to their software and should be able to tell you how to make it readable again. If they can't help you I would contact WD for help. Save the drive -- you may need to recover again.
Был ли этот ответ полезен?
Счет 3
Use free tool called Disk Drill, to recover your deleted videos. It's very important to preview your files before recovering. http://download.cnet.com/Disk-Drill/3000...
Счет 1
If you can not open the video, that means the video was not recovered completely. Try other better video recovery program like Card Data Recovery.
Счет 0
2 Комментариев:
hello,
Ok the issue is the data was lost on a mac and the recovery was done using a windows pc that is the reason the files seem to be corrupted. Is there a software or solution to convert it back to mac format.. thanks
из Поделиться
Probably not, because you now have a corrupt file structure, It can not simply be fixed by converting to mac format.
из Поделиться
Добавьте свой ответ
cyrus s буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 23
За все время: 3,741
