Repair guides and support for 17" laptops in the Pavilion Notebook 17 series. These laptops have model numbers 17-g000 – 17-g099.
Вопросов 16 Показать все
Laptop doesn’t boot makes clicking sound and then repeats
Laptop makes a click or spark sound around the CMOS battery area
17 inch HP Pavilion with i5 4th gen processor
Recently replaced my HDD to an SSD and when I went to test out the SSD I accidentally picked up the laptop to turn it around and forgot about the rechargeable battery which immediately turned off the computer.
I tried rebooting the computer again and it just turns on all lights with fan running and then few seconds later turns off and hearing a click sound that happens when you hard power it off (holding down the power button) and then repeats
What I tried already was resetting the power multiple times and also connecting with only AC adapter to no avail.
Это хороший вопрос?
Оценка 0
4 Комментариев
James Chen exactly what happened when you "forgot about the rechargeable battery" and turned your laptop over?
из
@oldturkey03 what I mean by that was when I picked up the laptop to turn it around the rechargeable battery came out of its battery contact pins and the computer completely turned off
из
Yes, that is what I thought. Have you checked the connectors/cables and traces to make sure that nothing came loose or got pulled off?
из
Yes I have took each and every cable out and re connected them.
из
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
well this happened to my old computer and was told that i fried the board while trying to replace my hdd
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
James Chen будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 560
