Rear headrest deployed. How do I get them down
2001 CLK Convertible my rear headrest deployed. How do I get them down
Это хороший вопрос?
Это хороший вопрос?
richard morris check this video and see if it works for your model as well. Or you can try what works for the 2000 CLK . You can reset them with the button that you normally use to adjust your headrest. To reset the rear headrest, which MB calls a roll bar, press the upper half of the button and hold it for 8 seconds until you hear the mechanism engage, then press the lower half of the button to lower the headrests.
Был ли этот ответ полезен?
Thanks oldturkey03 your Vedio is for a 2005. My car is a 2001. I tried pushing the button to the left of flasher and it did nothing
@richard morris I added the instructions from the 2001 CLK owners manual.
Hello. I have 2004 clk 500 that I cannot figure out how to lower the rear head rest. this car does not have the roll bar button thanks.
За последние 24 часов: 2
За последние 7 дней: 22
За последние 30 дней: 79
За всё время: 11,343
4 Комментариев
How do you get them back up I heard the noise on the button but nothing move thanks
из keithjones147
I have a 2007 s550 and the same thing happens with my car……. I hear a click but head rest stays up🤷🏾♂️
из oscar.summerlin
Mercedes benz ml350 no change ger at hot car
из Fazl
How can I manually lower the rear headrests in my 2004 Mercedes FLK 500?
из Mark Carter
