Are logic boards interchangeable on the Retina, 15-inch, Mid 2015?
There are five different logic boards for the MacBook Pro (Retina, 15-inch, Mid 2015).
- 2.2 GHz
- 2.5 GHz
- 2.5 GHz with dual graphics
- 2.8 GHz
- 2.8 GHz with dual graphics
Can I replace a bad 2.2 GHz board with a 2.5 or 2.8 board?
Swap an integrated graphics for dual graphics?
Are they interchangeable?
Это хороший вопрос?
4 Комментариев
i too am trying to determine if i can upgrade my MacBook pro 15" mid 2015 logic board with DG - AMD Radeon R9 M370X 2 GB and Intel Iris Pro 1536 MB graphics to a 2.8ghz DG?????
из geomatrixx
@geomatrixx - Yes its doable, but you'll need the second fan, dual chip heatsink and fan gasket as I explained below.
из Dan
Thanks dan I already have the 2.5ghz dual graphics so I think it will be a straight forward swap unless the 2.8 dual graphics heat sink is different to the dual graphics 2.5ghz,
из geomatrixx
Another question related to this, are the Logic Boards from and older 15" MacBook Pro with DG interchangeable? i.e a MBP 15" 2013 be used with logic board from a MBP 15" mid 2015?
из pboix
