Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
214вопросов Показать все
Ipad Air 2 Sleep / Wake Sensor transfer
Hi all, Recently i have come come across an iPad air 2 A1566 which i replaced the screen on. I also noticed it has a small sleep wake sensor at the bottom of the iPad to the left of the home button. This requires transferring from one screen to another and also involves soldering. I have tried to do this following a very vague guide on here which includes a video but to no avail. Could someone please provide a link or some step by step detailed instruction on how to do this correctly.
Thank you in advance.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hello David
https://www.youtube.com/watch?v=FVypx7p-...
If you do not have welding experience, it is difficult for a video to explain everything you need.
This video shows quite well how to perform the repair correctly. I don't have good English, but it seems to explain what is necessary for that repair.
Good luck!
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
David Harkness будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 51
