Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624вопросов Показать все
Display screen with "Red static colored"
I started to see “red static” on the borders and anywhere there's black on the screen. Doesn't show up on the Mac OS X boot screen. Pretty sure it's a hardware issue and not software since it goes away when I close the lid about 3/4 of the way down, but the problem is getting worse every day. I suspect that is the ribbon cable that connects my display to the logic board , any suggestion about how to replace it are welcome!
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Выбранное решение
Try starting up in Safe Mode by holding down the Shift key on start up. This will confirm if you have a hardware or software issue if the symptom disappears.
If it’s gone, install a good “Paid For” antivirus like Symantec and run it.
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
Hello,
Thanks for your reply. I test it on Safe Mode and the problem continue. So is Hardware :(
Regards!
из
Ok, now lets see if we can narrow it down. Hook up an external display and see it it appears on the external. If so, you have a GPU issue, if not then we go to the display.
из
A red screen is apple’s version of the blue screen of death.
Оценка -1
1 Комментарий:
So, Purple is Goggles screen of death ?
Red is just a color it's not a sign of a OS failure its a sign of a video signal getting messed up.
из
Добавьте свой ответ
Frankhil Contreras будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 10
За всё время: 5,555
