Original Apple Watch fixed but adhesive isn’t holding screen
I have my Apple Watch working again. But the adhesive isn’t sticking. I followed the directions and applied heat and wrapped it in rubber bands but the screen is still coming up.
Any recommendations?
Thank you!
TC
Это хороший вопрос?
What did you use in the repair? The force touch adhesive gasket and precut adhesive are both possible alternatives for use in the replacement / repair process. Did you use any of those? Heat is usually used to weaken/loosen adhesive not to strengthen a bond.
из drmdolfan
I used the force touch adhesive gasket.
из The UnderTECHer
Ok. I had not read that original ifixit screen replacement guide which I see recommended heat and rubber bands. If you followed the guide then be sure that you also made sure to meticulously remove all traces of leftover adhesive / gasket from all around the gasket and screen seating surface of the watch using a little bit of alcohol. Good luck!
из drmdolfan
