The iMac G3 came in tangerine, blueberry, lime, grape, and strawberry colors.
18вопросов Показать все
How do I install the MacOs?
Change the original 4GB HDD of this model to an 80GB one. But I can't install the system to use it again. I light it and the “?” Icon is flashing. Download and burn discs with MacOs 9, 8 and I can't make it boot from the CD. As I read it was to keep the letter "c" after the ignition but does nothing. I would greatly appreciate your help.
Это хороший вопрос?
Оценка 0
1 Комментарий
What is the make and model of the drive you installed?
из
Добавить комментарий
1 ответ
Выбранное решение
Partition the drive with one 8GB partition, and one 72GB Partition onto your IDE drive (do not use a SATA drive). Install the system onto the 8GB partition.
iMac G3 Model M4984 Hard Drive Replacement
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Horacio aparo будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 6
За всё время: 102
