Repair documentation and service information for Hisense televisions.
143вопросов Показать все
Why does my hisense tv turn on with back light but had not display
Hisense tv back light turns on but no display or sound.
i have tried replacing the tcon board but not sure what’s wrong. Tv did have a green side down the left hand side of the tv but now there is no picture at all.
i have ordered a main board to see if that helps. Any advice on the half green screen would be appreciated.
Это хороший вопрос?
Оценка 0
2 Комментариев
tv come on but see only light
из
@jambolewis have you tried any of the suggestions from the answers? What have you tried? What have you checked? What make and model is this?
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
@alisterd first off give us the complete model number for your TV. Then give us more information about the “Tv did have a green side down the left hand side “ since this can very well be a bad panel. Commonly so, since you have backlight it “could” be a bad main board. You do want to try all video input sources separately and see if that makes a difference.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
I have a 55a5800pw, water got in and the screen has no picture only show blue what could be the problem?
из
I know this is an old post but I just fixed the same model by replacing the eeprom that is located on the tab bond board. I figured it was worth a shot since I had a ton of these TV’s, mostly broken screens, and I save the old tab bond boards. I will go through the boards that I have and set up a listing on ebay if you can still use this fix. I used a 450 degree solder station heat gun and it went surprisingly well. If this can help anyone else my ebay username is JS-Electronics-Parts. Hope this helps anyone searching this problem and I am also going to attempt to make my first youtube video on this as well. Good luck to all.
Оценка 1
Добавьте свой ответ
Alister daire будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 9
За последние 30 дней: 51
За всё время: 4,409
