This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316вопросов Показать все
No display on top lcd when bottom lcd connected.
I was having the issue where the ds would turn on then immediately shut down and the top or bottom screen would flicker and i thought it may have been the F1 or F2 fuses, but after testing they seem ok.
After jumping a connection on the board the ds stays powered on with the screens connected but When the top and bottom screens are connected to the DS Lite’s mainboard, only the bottom lcd will function.
However, when only the top lcd is connected, it will work just fine. I am by no means a soldering expert, i’ve only been soldering for almost a month now.
I have tried looking for a solution and could not find one. Any help would be greatly appreciated, Thank you. The black color coded pins is what i have jumped.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Hi!
If the LCD cables are not correctly seated, it will turn on for a 1-3 second(s) and the screens flickers for a second and then it will turn off by it self.
Are you sure that both screens (and cables) are good? Did you recently replaced the lower screen? If yes, you need insulation on the back of the screen to prevent a short.
Был ли этот ответ полезен?
Оценка 0
5 Комментариев:
Yes i used electrical tape as insulation
из
And yes both screens do work, its just that if both are connected at the same time only the bottom will turn on. I'm wondering if it could be a power issue?
из
So there is no image displayed on the top screen when both connected? Does the top lcd stays black? Or just a white screen without anything on it?
из
it stays black
из
Can you also test with another top LCD ? Or motherboard? Just want to know if it's something motherboard/cable related..
из
Добавьте свой ответ
TheresEvilAfoot будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 61
