1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
191вопросов Показать все
I've got many issues with my MacBook air
Hello, I hope u r all fine.
I have a 2011 11” MacBook Air with an i5 my OS is Yosemite 10.10.5
I have been facing many issues lately!
  • It’s booting up when I connect the charger
  • The keys T, Y, U, I & O are not working!
  • The rest of the keyboard are typing different alphabet letters! for example if I typed M it will appears like € and so on for the rest keys
  • When I boot up the hardware sign is shows off and I need to select it to proceed to the OS
I need help pls
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
All of these signs point to a blistered battery which is pushing up from below pressing on the keyboard. As the battery has failed your Charger is now the only means for the system to get power which is why the system starts up on its own.
You’ll either need to find a local repair shop who can replace your battery or you can do it on your own but you do need to be careful! When I get a system like this I take it outside to remove the bottom plate and the battery as soon as the bottom plate is removed the battery has nothing to hold it back. This is when the battery can rupture and that is when the batteries can catch on fire! Make sure you have a safe work area outside and don’t have any flammable material on or around you.
Here’s an example of a failed battery!
Here’s the iFixit guide to open the system MacBook Air 11" Mid 2011 Battery Replacement and here’s the iFixit battery you’ll need MacBook Air 11" (Mid 2011-Early 2015) Battery
MacBook Air 11" (Mid 2011-Early 2015) Battery Изображение
Продукт
$59.99
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
jan mina будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 34
