The Xiaomi Mi A2 (Also known globally as the Mi 6X) was released by Xiaomi in July 2018 in various internal memory configurations. It is part of the Android One program which guarantees updates for two years.
41вопросов Показать все
Can a wet phone still be fixed after I charged it?
so i my phone got wet, at first it worked perfectly but after a few hours it turned off . i thought its battery died so i charged it and now it wont turn on or respond to anything. so can it still be fixed by a professional?
HELP ME PLS
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Yes there is still a chance to salvage a water damaged phone even after it’s been plugged in. However, keep in mind that by plugging it in you are introducing electricity to a board that could have unwanted bridges between components and that can severely damage a device.
Best thing to do would be to disconnect the battery (if possible) and bring it to a repair centre ASAP. Or, if you feel confident enough, try fixing the water damage yourself! Check out this link for some more info
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
so it turned off on me last night and i plan to take it to a repair centre tommorow, is that too long? (also thanks for your answer very helpful)
из
The sooner you bring it in the better. Every case of water damage is different so you couldn't really say when it's too late
из
Добавьте свой ответ
tato будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 6
За всё время: 85
