Released on July 28th, 2017, the New Nintendo 2DS XL is a handheld gaming console succeeding the Nintendo 2DS.
203вопросов Показать все
The top screen gets power but displays nothing.
Hi.
Some time ago I bought a damaged New 2DS XL. I knew the top screen would not work but replacing was not a problem. After opening it turned out that someone had previously tried to “fix” something and it looks like the picture.
Tape No. 1 is torn out, it has no socket (I know it's NFC) while tape No. 2 is glued (socket is damaged).
Is my fault due to these two tapes? If not, do you have any idea how to fix it? I know the top screen gets power because it gets brighter when I start it.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Hi @darkmagenta,
You can try to fix those but that requires some soldering skills and equipment. You can try to get a replacement board but it will be more expensive, especially that both of the tapes look damaged so you will need to replace those components as well.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Thank you for your response. I was afraid to change the board. It would be cheaper to buy a new console. That's why I was wondering if it could be repaired in any way.
из
Добавьте свой ответ
Kuba будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 6
За всё время: 128
