The Mercedes-Benz W126 is a series of S-Class automobiles manufactured by Mercedes-Benz between 1979 and 1992. Premiering in September 1979 as the successor to the W116 line, the W126 was the second generation to officially bear that prestigious designation, an abbreviation for the German Sonderklasse or "special class." The W126 was initially offered with straight-six, V8, and a turbocharged diesel engine for the sedan. A C126 2-door coupé versions was introduced in September 1981.
9вопросов Показать все
How to install a push button start on my 1983 Mercedes Benz 300 SD?
How to install a push button start on my 1983 Mercedes Benz 300 SD? Will this make it where I can start my car still if I lost the key or have problem with the starter? If so…this would be wise to install! Thanks
Это хороший вопрос?
Оценка 0
1 Комментарий
What is the real problem with the car? Is the engine hard to start, or is the key stuck and won’t turn in the ignition? Did you loose the key?
It would be bad to bypass the ignition with a push button, someone could easily steal your car.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Maria Stockstill “Will this make it where I can start my car still if I lost the key” you would have to rewire the ignition lock so that you get the accessory power going which you will still need even if you go for a push button start. So you will still need to have some additional switches installed. “have problem with the starter? “, no. A push button starter still only close the circuit to the starter. It will not resolve any starter issues. Take a look at the wiring diagram for your Benz to see what all happens on it.
Был ли этот ответ полезен?
Оценка 3
Добавьте свой ответ
Maria Stockstill будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 12
За всё время: 734
