Руководства по ремонту и поддержка Motorola Moto G6 Play, выпущенного в мае 2018 года. Номер модели XT1922.
Screen replacement ways to teardown without heat gun
Is there a way to teardown for screen replacement with out the use of heat gun to unstick qlue
Это хороший вопрос?
Счет 2
Добавить комментарий
3 Ответов
hairdryer works as well as a hot air gun or these guys sell a microwavable sack thing that you microwave and is designed for resting on the screen to melt the glue i think its called an iopener, but really you just need some heat to soften the glue a hot water bottle would work just as well as long as you make sure its dry
Был ли этот ответ полезен?
Счет 0
Any gentle, non-focused heat source should be fine. A hairdryer, space heater or radiator will all work. Just be careful to not get it TOO hot, otherwise you could damage the motherboard or LCD.
Счет 0
I personally use a gel hot/cold pack from the drug store. Microwave the pack then place on back of phone for a couple minutes and the back comes off in one go.
Счет 0
Добавьте свой ответ
Luis Andrade буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 8
За последние 30 дней: 70
За все время: 14,514
