The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
151вопросов Показать все
iPad 6 Screen has dead bar
Hi,
since I checked every forum and thread regarding my issue and found no answer to it, I am rather clueless now …
My iPad 6th Gen. has developed two completely dead bars. It will not respond to the pencil and to touch within the dead area … it worked completely fine until last week - did not drop or anything. It then startet with just one dead area (left one), then started to have another one … furthermore I thing the (original) left dead area is growing bigger :-( sometimes there is just the left dead area, sometimes there are two …
It also misstips - instead of an “e” it tips “g” … sometimes, when I press a letter, it won’t tip it but instead marks words randomly …
It tried everything I read (concerning iPad Pros) - turning off Bluetooth, resetting (soft and hard), assistive touch, turned it around etc etc etc - nothing helped
Of course out of warranty :-(
anyone has an idea what it may be and / or how to fix it?
Thankful for every help!
best regards!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
It’s a defective digitizer. It cold be normal wear and tear or perhaps some water got inside the iPad. You can replace this yourself by following this guide. Check out my answer to this question (After doing my repairs (battery and screen) I have problems) for some general tips on re-assembling your device as its not always clear from the disassembly guides on iFixit.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Sebastian Philipp будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 15
За всё время: 1,220
