Laptop not turning on
Hey guys, my asus X541UA not turning on.
1.not turning on
2.not light charging indicator and not charging
3.sometimes its on, but turning off few seconds.and also connect charging and lights on
Could you please tell me what the problem is?
Это хороший вопрос?
If it works with the charger connected then the battery is defective.
из mike
Thanks for replying. I removed battery but same thing happen.
из tharaka maduwanthi
@tharaka maduwanthi
Tharaka, Do you know if the charger is good?
из mike
Yes. I on my laptop without connect charger it not response.but after I connect to changer its on and immediately off.That happens twice or three times.after it not response connect charger and not light charging lED.
@tharaka maduwanthi
Try this:
Remove battery.
Connect a different charger, say borrow a friends, with the same voltage.
Does the laptop turn on?
Does anything appear on the screen?
When troubleshooting you want to eliminate possible causes so in this case we are trying find out if the battery or the charger is the problem
If it is not the battery or charger causing the problem then it is something on the computer's main board.
из mike
