Apple выпустила смартфон 4 ноября 2017 года в двух различных конфигурациях: A1865, A1901 и дала название iPhone X. Доступны варианты с разными стандартами мобильной связи: GSM или CDMA; с двумя объемами хранилища: 64 или 256 Гб; двумя различными оттенками корпуса: серебристый и Space Gray.
1199вопросов Показать все
Warranty on screen with ghost touch.
I have a iphone X and it is about 20 months old, Apple have a screen replacemt program for the iphone X when the screen has a defect (not when it have a broken glass),
https://support.apple.com/en-gb/iphone-x...
I have made a apointment by Genius Bar last week but in the mean time my phone felt on its back and the rear glass is broken. Will Apple replace the screen or refuse it?
A article on the web show this text :
The waranty does not apply to cosmetic damage, including but not limited to scratches, dents, and broken plastic on ports, or defects caused by normal wear and tear or otherwise due to the normal aging of the device. If no hardware issue is present and cosmetic damage is the only reported issue, then deny a repair or replacement.
Это хороший вопрос?
Оценка 1
4 Комментариев
Hi. Wanted to know if you got your iPhone X display replaced by Apple?
I have the same problem. The ASP are the only option in India & are denying to replace the display stating silly reasons that it will further damage the back glass!
https://i.imgur.com/ptVuUps.jpg
из
Yes, Apple have place a new screen under the replacement program for screens that have unresponsive area. But your phone must be without damage, no cracked back glass and front. I did put mine logicbord and unresponsive screen in a secondhand as good as new original Apple backhousing. Prior to visit Apple for replacement.
из
I see that your's back glass was also broken to so in that case I wanted to know if Apple replaced it for free?
из
I put mine logicbord and unresponsive screen in a secondhand as good as new original Apple backhousing. Prior to visit Apple for replacement.
из
Добавить комментарий
1 ответ
Выбранное решение
that would be at the discretion of the particular “genus” you deal with. honestly i would say go to a best buy since they are a ASP and have them do it. ive had them do a few that were defective and just did the back glass myself.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Leslie Leslie будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 1,232
