Model A2159, EMC 3301. A refresh of the entry-level 13" MacBook Pro. Available in Silver and Space Gray. Released July 2019.
112вопросов Показать все
What happened here? MacBook Pro 2019 13" Display / GPU problem?
So my Mac was in sleep mode as usual. Charger connected. I have never experienced a problem such as this. First, I opened the lid then all of a sudden this is what I see. I could log in and do stuff. (The Touch Bar was working this is how I can confirm that!) Then I closed it down and opened up again but this time the login screen appeared as normal. I would be glad if someone could explain me why this happened, furthermore help me decide whether I should bring it back or not.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
It looks like you have a bad display here! Yep, time to visit Apple Store to get it fixed or replaced. If you haven’t signed up I would strongly recommend you get AppleCare + service contract.
Был ли этот ответ полезен?
Оценка 1
4 Комментариев:
Yeah you know this is what I thought at first but it looks more like a software failure. See, my cursor was showing up as a bright square and I could move it with the touch pad. However the other problem is there isn't a single apple store in my whole &&^&^$^ country. So I think If I ever see this problem again I will immediately return it back to T-Mobile. Thanks for the help though!
из
Take out that extra two years of AppleCare coverage if they don't replace your machine. However I would also install a good "Paid For" anti-virus program and run it, to insure this is not an infection. (Also, 70% of the Macs that come in to me now have viruses)
из
Thanks for the suggestion, I installed and subscribed for Malwarebytes premium plan! It said my system is clean of any infection! ;) @mayer
из
Don't delay on getting to the Apple Store or authorized service center to get your system repaired under warranty!
из
Добавьте свой ответ
Dániel будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 8
За всё время: 232
