The Nintendo GameCube Controller DOL-003. Released November 2001, compatible with Nintendo GameCube, Nintendo Wii, Nintendo Wii U, and Nintendo Switch. Repair for this device is straightforward and requires only common tools.
46вопросов Показать все
gamecube controller drifting when I move left
I noticed that when I play super smash bros ultimate, even when i push my control stick to the right, my character goes to the left. I think it is a drifting issue, can anyone help me with this issue?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
I had a Wavebird that was having the same issue. You need to replace the stickbox. You can order an aftermarket stickbox from Amazon or Aliexpress. What I prefer to do is to get a Wii Nunchuk with a good stick and desolder the stickbox. The Nunchuk and Gamecube controller use the exact same stickbox so you can simply solder it onto your Gamecube controller.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Was is the stickbox? Do I need a screwdriver to get the stickbox out?
из
The stickbox is what actually reads your stick movements. To replace it you'll need a Tri-Wing screwdriver and a soldering iron. Here's a tutorial. https://www.youtube.com/watch?v=KpZFeJU9...
из
Добавьте свой ответ
Pokemonman You будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 10
За всё время: 3,605
