Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212вопросов Показать все
USB/Ethernet/all ports not working
The USB/Ethernet/all other ports on the back of my iMac have stopped working. I plugged a USB cable in and it touched a lamp with a short--it arced and now the USB and Ethernet don't work. The computer boots seems to work fine, but I can't interact with it via keyboard/mouse/ethernet. The airport is off so I can't try connecting via wifi.
My guess is the bus with the ports has been fried. Is this on the logic board, or is it a separate board that's easier to replace?
In addition, any ideas on how to connect/interact with the computer without the use of USB/Ethernet/Wifi?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
You're probably looking at having to replace the logic board. You may be able to get to the bluetooth by disconnecting your keyboard and starting up.
Был ли этот ответ полезен?
Оценка 1
Наиболее полезный ответ
if you have a bluetooth module, you can try using a bluetooth mouse and keyboard. your imac should ask you pair a keyboard and mouse if you have the bluetooth installed.
as for the damage, the ports are part of the logic board. i have never seen the come seperate. i would have to say
Оценка 1
Добавьте свой ответ
Reed будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 5
За последние 30 дней: 6
За всё время: 946
