press the button to start it does not start making a click noise
I have a Kenmore 796-61512210, it turns on and I am able to make the selection for the time but when I press the button to start it does not start making a click noise. These are the items that I have replaced:
- control board- behind the front panel board.
- front panel board where the switch is located.
- both thermal fuses
- Verified the front door switch with an ohmmeter and is working
What else it could be?
Antonio
Это хороший вопрос?
Оценка
0
Hi,
Have you checked if power is getting to the motor?
Also looking at the parts there are three thermostats as well as a thermistor which may be worth checking.
Don't know if this is what you meant by thermal fuses.
Just a thought.
из jayeff
