Where in the uk can I get 4.5 mm JIS #000 screws.
where can I get the screw that holds the case on in the uk every serch I have tried comes up with screwdrivers?
Это хороший вопрос?
Это хороший вопрос?
Les Swaffer reason for that is that the screws are not properly measured. iFixit measures the length of the screws but not the diameter. The Length is 4.5mm but the screw size is actually a M1.7 X 4.5 The #000 refers to the Phillips size head and thus the reason why your search will return screwdrivers.
In short, the screws you need for your camera are M1.7 x4.5mm Fujifilm part number is F085-0352-001
Был ли этот ответ полезен?
Thank you much appreciated
Les
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 77
