Shorted 0.8 amps No Usb Detected not charging
I have iphone 8 shorted 0.8 amps no sing of heat no sing of damage device was full shorted on VDD main used short killer to remove the short device is ON now and getting 0.8 amps short on VDD main NO USB AND CHARGER can any one have any idea ??
Это хороший вопрос?
2 Комментариев
We will need the history of the phone plus a little more info. You say that you used short killer to remove the short on VDD main but then saying there is still a short on VDD main.
• What is DCPS before prompt to boot?
• What voltage did you have short killer set to?
• What component did you remove to relieve the short?
из Chris Stables
It was full short before i used 1.5v in short killer to sense the heat but after using short killer for once it it removed the full short and turned on the device and now iam getting .8 amps while i connect the supply to the board with out turning on and when i make it on then its not charging and the apms short is still .8
из KHAJA ARSHAD MOHIUDDIN
