Motorola released the Droid Turbo 2 in late October 2015. Model number XT1585.
29вопросов Показать все
sim card is block for call, sim is not from verizon
I am using Moto Turbo 2 Droid, in start it work well, now it is blocked for SIM card giving error that, SIM card is not from Verizon but before it not giving error of SIM.
unable to start calling i setup SIM on global setting.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Verizon requires that the device be owned 60 days, then the device will be unlocked. Otherwise, other SIM cards will be rejected. Also, is the card GSM? Verizon phones are only CDMA-compatible.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
60 Days owned? what that mean?
Yes the card is GSM.
из
Well, there's your problem. Verizon only uses a CDMA network, which does NOT work with GSM cards.
из
If your SIM card is blocked for calling, it's most likely because it's not from Verizon. In order to make calls on a Verizon network, your SIM card must be activated with Verizon. You can do this by either purchasing a SIM card from Verizon or by transferring your existing SIM card to Verizon. If you have an existing SIM card that you'd like to transfer to Verizon, please contact us and we'll be happy to assist you.
See more info https://grouphowto.com/verizon-sim-card-...
Оценка 0
Добавьте свой ответ
Kamran Shah будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 5
За всё время: 308
