Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708вопросов Показать все
iMac goes to a grey screen half way through startup
I have a mid 2011 27” Imac with an SSD which has been installed for the last 6 months without problem.
Two days ago whilst working on the Imac the screen went to a blank light grey screen.
I tried rebooting the machine but half way through the boot timer the screen drops to the same blank light grey screen and will try to reboot on its own accord, which inevitably returns back to the blank screen half way through the load process.
I have managed to get into the hardware diagnostic which gave the fault code
4SNS/1/40000000: TH00-9.000
Could anyone please help?
Many thanks.
Это хороший вопрос?
Оценка 0
1 Комментарий
Hi Mayer,
Thanks for taking the time.
No I used a fan control app which I thought was working just fine.
I ordered and fitted the cable you refer to yesterday but I still have the same issue.
Do you know how I could diagnose the fan?
из
Добавить комментарий
1 ответ
Выбранное решение
Sounds like a fan error. When you did your hard drive upgrade, did you use the OWC thermal sensor?
https://eshop.macsales.com/item/OWC/DIDI...
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Guy будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 5
За всё время: 120
