Point and shoot camera manufactured by fujifilm in 2016.
camera showing turn off and on again
When turn on camera, it shows turn off and on camera ,after doing it it showing same thing.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Parul the most common issue for that is a stuck lens. If your camera upon turning the camera on feels that it can’t be properly extended or retracted it can give you an error like that. Check between the lens and the camera body for any sand, dirt or any damage. Try turning the camera with the lens facing down and shake to dislodge anything stuck and try removing batteries and memory card, wait 5 minutes and reinsert the battery and try again.
Yes, so please try compressed air. Use a vacuum cleaner with a small tip and use it between the lens turret and the camera body. It should remove all dust and sand. Check on here for some possible solutions.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Thank you, will try that
из
Добавьте свой ответ
Parul буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 2,568
