Start vehicle it runs for a while the shuts down, have to wait for a
I have a 1997 grand caravan it will start but after driving a little while it shuts down I have to wait about a hour before I can start it again
Это хороший вопрос?
Это хороший вопрос?
The fuel pump is going out most likely. I owned two of those vehicles and that is a common failure. It requires dropping the tank to replace it so it is a fairly pricey repair and not a job most DIY’ers are advised to tackle. I did one on the first caravan I owned. Remove battery ground strap before attempting tank removal!!! Keeping sparks and hot incandescent lights away from gasoline and fumes cannot be stressed enough!!!! You will likely need a second person to help you lift and position the tank when reinstalling. Link for fairly comprehensive tank removal procedure
Был ли этот ответ полезен?
Tengo el mismo problema solo que al checar la chispa de la bobina se pierde, deja de alimentar el sistema de distribución.
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 57
1 Комментарий
scooby1846 sounds like a fuel issue. what engine size does your GC have?
из oldturkey03
