The March 2019 refresh of Apple's iPad Mini tablet, featuring an A12 Bionic SoC and an updated True Tone Retina display with Pencil support. Available in Wi-Fi and LTE with 64 and 256 GB storage options.
32вопросов Показать все
How to fix a water damaged lcd of Ipad Mini 5
Walking in the rain with an umbrella, the Mini 5 was in a bag but somehow its still wet, any idea on how to fix this? Since it’s water damaged I don’t think apple is gonna fix it under warranty.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
The water seems to have got in between the LCD. Not sure if its possible for this ipad but the LCD it self is made up of different layers and would have to be taken apart and replace the sheets that are wet, this was easy to do in the earlier versions of the iPhones. The sheets can also be cleaned but that’s very hard because any dust or smug will be left behind and be visible. I would just say you need a new LCD. To get his done at a shop should cost you around $200 or less. Unless someone else knows how to get this done another way. You can also try Apple and just not give them that story and make up another?
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Geary Audie будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 19
За всё время: 1,224
