4-дюймовый iPhone выпущенный в марте 2016 года на той же самой платформе, что и 6s. Доступен в серебристом, сером, золотом и розовом цветах с 16/64 Гб памяти. Модели A1662 и A1723.
1049вопросов Показать все
What do I need to do and get to fix touch ic
I have a iphone se that I posted about earlier, ill put the link in the description. I watched a video of a person repairing a 5S and he used a heat gun and some brownish liquid substance, but there is no video for repairing the SE touch ic. I do have a soldering iron that can microsolder and I am experienced in soldering but im new to iphone motherboard repair and microsoldering. I am on a tight budget so can I just order the touch ic and fix it or do I need to get a heat gun, the substance?
also Is there a video for repairing the touch ic on my iphone SE?
iPhone se touch intermittently unresponsive
Update (03/07/2020)
I already have a lot of supplies for microsoldering except a hot air reflow. soldering paste, and wickets, do ineed those too?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Brayden, if you want my honest opinion…this is not something you should follow through on if your goal is to actually repair this phone on a budget. If your goal is to learn, then go for it.
Your question shows that you really do not have the proper tools, consumables and experience in micro-soldering and that you will probably muck things up more than anything else. I don’t say this to be harsh, just to save you time and money. If you really want this phone to work and quickly, let someone else do it.
That said, I don’t think you should be investing money on a water damaged device. I don’t know any techs that actually fix water damaged devices, they can have all kinds of latent issues and are a warranty nightmare.
Now, to be fair, if you want to learn then you will need a hot air gun, paste flux, good tweezers…and tons of practice on dead boards before ever attempting to repair a valuable device on your first try.
Feel free to ask any follow-up questions!
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
thanks, I do solder but i havent encountered microsoldering. I just have a soldering iron that will do it. I do have a LOT of dead boards so ill practice on those, thanks
из
Добавьте свой ответ
Brayden S будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 12
За всё время: 175
