Nintendo Game Boy Advance, released in 2001. Repair requires only common tools and no heat.
54вопросов Показать все
Why is my gameboy not turning on?
I have replaced my gameboy with new batteries after seeing there was a red light showing with the old ones. Once I did this the gameboy is now not turning on at all. I also have got a Gamester power pack and my gameboy won't charge on that. When I plug the gamester into the socket the green light is on but the red light isn't coming on. Can someone please help me ?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Is there acid corrosion inside the battery slots?
The best way to remove alkaline leakage from the device is to neutralize by carefully dabbing with a few drops of a mild acid like white vinegar or lemon juice on a cotton swab or an old toothbrush to clean it off.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Gamegirl будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 6
За всё время: 122
