Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
iPhone keeps restarting while not charging
My iPhone 6 restarts randomly and starts boot looping. Sometimes it immediately restarts when unplugged, sometimes it takes opening an app, opening the control center or just doing something in any app. When it is charging, everything works like normal, and it stops boot looping if it currently is. The battery was replaced in 2016 at a third party repair store, and worked until recently. Last December I noticed that the left side of the device was bent open and could not be closed, and inside it looks like the battery is thicker than normal, stopping the device from being closed. I didn’t notice any other damages or anomalies, not even anywhere on the battery. Should I simply replace the battery, or are there any other possible causes?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
You definitely need to replace your battery. After a few years they can no longer deliver the right amoutn of power the phone needs, so it will do odd things like restart, bootloop, etc. Since the battery is bulging, i would highly suggest to not charge or use it until the battery is replaced because it is unsafe.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Korbinian Rest будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 76
