wihle updating bios it was damaged
i can not turn on the laptop.
how to recover dameged bios ?
Это хороший вопрос?
Это хороший вопрос?
Был ли этот ответ полезен?
computer didn't light up at all. it was dead.
i thik that i can to recovery bios from usb . but i don’t know how to do it.
This is a long shot. No promises.
Have you tried it with the charger plugged in?
You could also take out the battery and leave for a day and then try with just charger.
Does anything happens, lights, etc.?
i tried with charger , i take out the battery. but it not turned on at all. no green lamp. no red lamp (when charger is plugged.)
i plugged disk on key with bios file , press ctrl + home + power on (with plugged charger). but it did not turn on.
but i payd atention , wile pressing power button for 10 sec , the plugged disk on key makes one blink. what it means ?
Maybe someone knows where can I find the schematic of this computer (asus e203m)
Abcde Abcde….try this for bios update via usb:
after this update it dead. and i can not turn it on
if it is truly a bios issue, you can remove the bios chip and reprogram. i have a feeling your troubles lay elsewhere. unless you have an chip reader/programmer and soldering tools, youll want to take this to a shop.
o.k.
bu i did not find the bios chip in this motherboard. i did not find cmos battery to make bios reset too.
@Abcde Abcde what is the board number? upload a picture of your board so we can assist in finding what you need. do you have the tools to complete this task? soldering station, eeprom prgrammer> if not, bring to a local shop. have you verified that there is voltage going into the device from the charging port?
i buy all the tools. but how can i find the bios version for eeprom prgrammer ? can i download and use the asus bios ?
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 9
За всё время: 537
