Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
342вопросов Показать все
Can display data cable make my screen go blank
My intel iMac Pc was not powering so i opened it up remove the power supply and changed the capacitor this solved the problem for a while later same problem occured fixed it again and coupled it back even with the data display cable tucked in properly the system gives sound on power up but nothing to show on display how do i fix this
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Выбранное решение
To verify that its the display or a display compontent, plug in an external monitor. If you see something, then its the display, if not, its your logic board or your GPU.
Был ли этот ответ полезен?
Оценка 3
I did a hard drive upgrade, and at first, my screen was blank, but would show up on my TV, it turns out the cable's lock is VERY sensitive, and you have to plug it in properly, then be careful with the LCD. For some reason, it does not work when I had the torx screws around the LCD in too tight.
Оценка 0
Добавьте свой ответ
bayoadenuga будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 6
За всё время: 1,139
