Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
310вопросов Показать все
Internal display black, external workings fine but...
iMac working on external display
  • problem
  • Inbuilt display not working .
  • There are only 3led physically present on motherboard No.4 which is mentioned in attached image start with iMac start but turn off automatically after few seconds.(after removal of lcd screen)
  • but still external display working fine.
  • Very very light display appear sometimes.
confused
  • inverter problem?
  • lcd to inverter cable problem?
  • backlight problem?.
Это хороший вопрос?
Оценка 0
2 Комментариев:
likely you snapped some cable while disassembly. Carefully disassemble and check everything.
> Mac hdd show multiple error message while OS X installation.
Next this happens, use something like http://www.system-rescue-cd.org/ ISO on a USB stick to verify and check HDD/SSD. command: smartctl
Just do not disassemble immediately.
из
- Everything I solved successfully .
- No cable snapped checked twice
- Now facing Only 1 problem screen problem (very light display)
- I know it is inverter or lvds cable or back light or in same cases vertical synchronise cable problem.
- Need help how to diagnosis one by one?
из
Добавить комментарий
1 ответ
You need to replace the LED driver board.
iMac Intel 21.5" EMC 2308 LED Driver Board Replacement
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Kailash Kamble будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 82
