{A1706 / EMC 3071}—Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz.
Вопросов 20 Показать все
Mac won’t turn on after screen replacement
I was fixing a friend’s MacBook Pro 13” 2017 with TouchBar. I’ve worked on Macs and iPhones hundreds of times. I opened up the bottom cover and undid the pancakes screw to disconnect the battery and bent the flex cable back a bit to make sure it doesn’t contact the battery during repair. I went ahead and replaced the screen and then replaced the battery connector and screw.
After, I tried turning on the MacBook and I got nothing. No backlight on keyboard, no chime when I plug in power adapter, and no response from trackpad.
I went ahead and did the SMC reset and PRAM reset, but I got nothing. I then went back and replaced the new screen with the old one thinking the new one was defective or shorting out somewhere.
Nothing with the old screen either. So I put the new screen back on. I did some trouble shooting and found out if I leave the battery connector disconnected, the MacBook powers on with the power adapter plugged in. when I connect the battery back to the motherboard, it doesn’t power on even with the power adapter plugged in.
I think it’s safe to say it’s the battery or battery connector to the motherboard. Not sure if that connector piece is replaceable or not.
Any advice would be greatly appreciated.
Это хороший вопрос?
Оценка 2
3 Комментариев
Curious what @danj has to say, but thinking maybe something with the battery connector?
из
did you follow the guide? MacBook Pro 13" Touch Bar 2017 Screen Replacement. Did you disable Auto Boot?
из
@danj I did not disable auto boot unfortunately, I did everything else however. Is the MacBook only useable with the power cable now or can it be fixed?
из
Добавить комментарий
Ответов (6)
Выбранное решение
I sent off my MacBook to a repair shop that handles board-level repairs, and they confirmed it was the battery that was causing the issue, not the motherboard or power connector.
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
So changing the battery fixed the problem?
из
Was the battery replaced? And did the MacBook turn on after the battery replacement? I'm having the exact same issue but I replaced the trackpad on my A2338 MacBook Pro 13"
из
When this happens simply disconnect SMC ribbon cable and pancake battery screw first, then unclip all the Connectors that are accessible when back cover plates are removed... wait a few minutes. Reconnect all Connectors and protective plates then, the pancake battery screw and SMC ribbon cable. Turn MacBook over insert charging cable and lift the lid, your MacBook will turn on... after Initial start up it will turn on with or without charging cable connected
Оценка 2
2 Комментариев:
The data ribbon cable connector on the battery got damaged so this wouldn't help.
из
Plugging it into a charger to boot up solved it for me! Thank you a ton!
из
Ouch! I haven’t encountered that so I just don’t know. I think you’ll need to bring the system into Apple when they reopen.
Take some pics of the logic board markings as well as the systems S/N number, so when you get the system back you can see if they exchanged out the logic board.
Оценка 0
8 Комментариев:
Yeah I suppose that will be my only option now. Can you help me understand why disabling auto boot is necessary if you’ve already unplugged the battery before doing the repair? Thank you
из
Basically, the system is still powered! So when you start disconnecting & reconnecting things you can damage the logic.
из
@danj interesting, I always thought once you powered down the device, undid the battery connection, and held the power button for a few seconds afterwards, the entire system would be cleared of power
из
TouchID changed things! Now its powered all the time! If you store your system you need to do this as you can kill your system if you don't!
из
@danj so, as it turns out, Auto Boot was in fact disabled prior to the repair. Does that change your diagnosis?
из
Показать 3 больше комментариев
So I did this and still no change on the screen I hear the boot up but I didn't get a screen turn on or anything please help
Оценка 0
1 Комментарий:
Did you checked if maybe your charger is damaged? 😂🤣
из
Please help.... same issue here but I can't afford to pay for $800+ professional fixing after already paying $500 for the replacement screen..... won't turn on backlight/screen/touchbar, and I even replaced the SMC ribbon cable :'(
Оценка 0
Before I replaced my screen following these instructions, I knew the problem was the ribbon cable that I'd damaged trying to remove the Macbook Pro strip at the bottom of the screen - so I knew the computer was fine.
I followed these directions to the letter, but ended up with a computer that wouldn't power up nor charge by the end of the job.
After taking the computer to a professional, I learned that I'd unknowingly blown a number of chips on the logic board because I didn't adequately ground myself before doing the job. So, I saved a couple hundred bucks replacing the screen myself, but had pay hundreds more to get the chips replaced at a "non Apple certified" repair shop, and the "authorized" shop in town was just going to send it back to the Mothership to get the job done cheap and easy for the flat Apple fee.
The local shop did the work and fixed the problem, and was able to maintain all the data on my hard drive. Apple was going blank it out 100%.
So, lesson here is to ensure you ground yourself before doing any job you see here in iFixit.
Оценка 0
1 Комментарий:
Did you happen to plug in an external monitor before making the switch to a new screen? When my screen died I plugged in an exernal and as expected computer was workng fine. Got a new screen and replaced according to instructions, but screen not working. Plugged in external and found I get a screen, but not an apple boot or login.Now not sure if i got a fualty screen, or the computer now somehow has a different issue, that wasn't there before o swaped the screen.
из
Добавьте свой ответ
Khawaja Shah XI будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 8
За последние 7 дней: 57
За последние 30 дней: 188
За всё время: 16,943
