A portable, rechargeable jumpstarter that can provide instant jumpstarts for cars and trucks.
Why is my rescue 900 jump starter not charging
Green light saying fully charged when My jump starter is plugged in but its dead..will not charge
Это хороший вопрос?
Счет 1
3 Комментариев:
How old is the unit? Sounds like the batteries are at EOL (End of Life), they are normally replaceable.
из
the device cannot switch off
из
it is new just three months only, when use it first time it has this problem
из
Добавить комментарий
1 ответ
If you don't keep those things fully charged at all times they won't take a charge after a while. Also if you don't fully charge it before first use it can really hurt the internal battery. Hope that helps. I'm in same predicament with mine.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
so what do you do with it?
из
Добавьте свой ответ
Shannon Staggs буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 26
За всё время: 2,764
