Released in March 2017, the Moto G5 Plus (model numbers XT1687, XT1680, XT1684, XT1685) includes a 12.0 megapixel rear camera, a 5.2 inch screen with a 1920 x 1080 resolution, and the Android 7.0 (Nougat) operating system.
Replacing the Adhesive(s) after battery replacement
There is no description on how to use the sticker in the fix kit to replace the adhesive to hold down the screen. The adhesive strips for the battery is pretty self explanatory, but I don’t want to get it upside down or whatever.
Thanks!
Это хороший вопрос?
Оценка 2
1 Комментарий:
It seems the comment below was talking about the battery adhesive and not the screen adhesive. Did you ever get an answer on this or have luck figuring out how to use and orient the adhesive?
из
Добавить комментарий
Ответов (1)
With the text in the correct (readable) orientation flip the battery over from left to right or right to left, the adhesive strip will have (typically a pull tab) that when applying the strip on the bottom side of the battery should point downwards towards the repair technician similar to the application for iPhone 5, 5C, 5S battery adhesive
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Robert Lynch будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 161
