Смартфон был выпущен 22 сентября 2017 года в двух модификациях: A1864, A1897, доступный GSM или CDMA модулями. Встроенное хранилище есть на 64 Гб или на 256. iPhone 8 Plus увидел свет в трех оттенках корпуса: золотом, серебристом и Space Gray.
627вопросов Показать все
Got my screen replaced and now the colors are all messed up?
Hello!!
I recently broke my phone screen and got it replaced (not at Apple). The colors of my phone are all messed up now. The contrast + saturation of my screen is really high, and all my pictures look really ugly and distorted now. I tried fixing it in settings in color filters, but it didn’t work; the contrast and saturation are too high. Also my increase contrast is off. What do I do??
Это хороший вопрос?
Оценка 3
Добавить комментарий
3 Ответов
Наиболее полезный ответ
I’m not one to usually assume things, but I have seen this way too many times and it’s usually caused by the person who completed this repair. Most cases are the person installed a really cheap aftermarket screen and those usually tend to have issues with contrast and saturation. This person also may have skipped this important step when repairing this specific phone found here: https://www.youtube.com/watch?v=xMeAnY_j...
Programming the screen is needed for the light sensor and true tone functionality to work and so many people/repair businesses fail to do so. Do you see any text that says “True Tone” found in settings < display and brightness?
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
yes what do i do after that is there a way to fix it?
из
Hi toreskey. Is there any way to tell if high saturation after screen replacement is due to lack of TrueTone or low quality of the replacement part? Are there any specific colors that can be analyzed to determine if the problem is caused by not programming the light sensor?
из
I have an iPhone XR and the same thing happened to me (off brand replacement screen). I fixed it by using the color filters in the settings (Display & Text Size > Color Filters). I ended up using the Color Tint (the Hue selector was about 1.5 the size of the word “intensity” and the Intensity was between the T and E of it). I hope this helps.
Оценка 1
3 Комментариев:
@jaemeappel thank you so so so much, this actually helped a lot.
из
Can h help me idk how to do this
из
@Jaemeappel thank you so much for giving this suggestion. I have an iPhone XS Max that I had to get the screen replaced on two days ago. I took it to CPR store and let them fix it. Ever since I got the screen replaced it has been so bright and it would drain my battery more quickly. I just had the brightness setting barely on. I Googled what to do about the screen and this was the first result that showed up. I did what you said by changing the color filter setting. My screen is now the appropriate brightness it should be. Hopefully this will help with my battery not going dead as quickly. Thank you so much again for posting this.
из
My screen is not in colors it always is
Оценка 0
Добавьте свой ответ
Jojo A будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 26
За последние 7 дней: 252
За последние 30 дней: 1,138
За всё время: 21,112
