AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
65вопросов Показать все
Repair or replace MagSafe to MagSafe 2 Converter?
My MagSafe to MagSafe 2 Converter has become loose. One side of the laptop side is lose and when pulled out it will not conduct electricity to the laptop. Pushing it back in fixes it.
Try some superglue? Try to purchase a replacement?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
It just fits into the outer sleeve. Some super glue should work fine, just don’t get it on the contacting surfaces.
If you can I’d actually try to pull it our a bit more, apply the super glue the push it back into place. Maybe softly use some vice grips to hold it in place till it sets up.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
James Harrison будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 11
За всё время: 117
