1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
189вопросов Показать все
MacBook Air drive won't boot up after repair, hard drive is locked
Hi, I recently repaired my old Macbook Air keyboard. After putting it back together I am getting a white screen with Apple logo and spinning circle. After pressing CMD+R and trying to repair disks in Disk Utility I get this message.
Disk Utility stopped repairing “Untitled”
Disk Utility can’t repair this disk. Back up as many of your files as possible, reformat the disk, and restore your backed-up files.”
Error log shows “incorrect block count” for “kernel.log”, “secure.log, 2015.01.01.asl”, “2015.01.01.G80.asl” and “2015.01.01.U8.G80.asl”. Also it shows “invalid index key”
When I try to reinstall OSX Lion, it says I cannot because the hard drive is locked.
I have no important data on here, just want to be able to get the disk to boot.
Any help would be much appreciated.
Thank you!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Hi @eddywilde
I have a feeling, by chance, the SSD is failing.
Perform further diagnostic test to check.
I know some flash memory, if there are alot of corruption blocks, it may force to read only.
If you have a spare SSD, suggest you to test out
MacBook Air 11" Mid 2011 Solid-State Drive Replacement
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Eddy Wilde будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 134
