Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
163вопросов Показать все
There was something rattling in my controller and this came out.
Where is this piece supposed to go? It fell out when I opened it
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
You may check out all these teardown and replacement tutorials, as I can see that the metal component can only be attached to the controller board, you may try your luck and find it there.
https://www.youtube.com/watch?v=5P0Seo7e...
Xbox One Wireless Controller Teardown
Xbox One Wireless Controller Model 1708 Button Replacement
Xbox One Wireless Controller Model 1537 Изображение
Инструкция
Сложность:
Модерировать
10 - 25 minutes
Xbox One Wireless Controller Model 1708 Front Buttons Изображение
Инструкция
Сложность:
Сложно
30 minutes
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
The piece that fell out was plastic, it probably looked metal due to the lighting. I will check out the teardown videos and see if they can solve my issue.
из
@logibeak Did you reassembly it again? Will it work?
из
Is this the part that go on the side of the analog stick module where the joystick button is ?
Оценка 0
Добавьте свой ответ
Coulton Manning будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 12
За всё время: 760
